Yes, it does swx (from various versions), it does alibre, but if not.Is it possible with you? I saw that both swx and alibre can do it without additional software.
It's true that I can export to jt that's about the same, but then the jt reader almost has no one.
I don't have a sigh sob license!the rare times that I had need of this kind I used, profitfully I have to say, “web publishing”,.
the attachment is a .exe that contains both the 3d file and the viewer (plug-in for ie, with firefox does not work).
Try it and let me know what you think.
you must be administrator to install the plugin and view the files... and this is not good in professional environments where you almost never have the admin pass.the attachment is a .exe that contains both the 3d file and the viewer (plug-in for ie, with firefox does not work).
I agree with the ominoadmin, but it is not the same ease of use.to this I had not thought, however clear that the installation should be made 1 time only , moreover it is possible to provide in files to display in html and not .exe format.
and anyway the omino admin can also raise the c..o from the chair and go do your own job and install stuff!:biggrin:
It happens to me every day, and lucky when they don't ask you to print them.....that if they did it in half the time they would have them, since in technical department they never do anything....so they say the owners.I agree with the ominoadmin, but it is not the same ease of use.
try to explain to one of the many owners (great farmers) with which we have to ke do ke you have to install a program.... ah no...
if you give him a pdf instead there is perhaps some chance that they can open it (not turn it however, too difficult)
I see it well with adobe reader 9.3. with foxit actually is white... .the pdf is beautiful white :smile:
I'll see if I follow the procedure and what comes out of it. But here's the solid is monolithic, but with the alibre printer I can see the various components together and show them or hide them as I prefer.I do this...
I don't know latex beforehand.
I use meschlab importing a stl and carry it in u3d so...
I installed miktex... and for hunter should not be a problem.
so I installed winshell as a latex editor that among other things is the only one that works for the pdf3d, which reads out of meschlab a tex file coming.... conceived at the same time as the u3d.
then I generate pdf .
Frankly, I use it a bit... I don't remember making who knows what other elucubrations to install it.
greetings
I don't want to install adobe,too heavy.vado in confidence.I see it well with adobe reader 9.3. with foxit actually is white... .
with pdf x-viewer also I do not see the 3d, while with acrobat you...I tried to include a draft - pdf within the previous pdf.
education to pass to latex should be about this.
skin
