test termico
  • Thread starter Thread starter Max-C
Max-C
Good day to all,
I wanted to ask you how to put components such as peltier cells to create a thermal simulation in solidworks simulation.
should I draw them by putting a material (which I don't know which one is) or are already present?
also how do you insert an airflow to simulate the air moved by the fans?
if you want to do complex thermal analysis, peltier cells + fan flows you have to use floworks / solidworks flow simulation. there are tutorials with all the explanations of the case. There is exactly the example that you indicate
I tried to look but can you tell me the name of the tutorial that makes peltier use?
I unfortunately can't find it....
you have to look for tutorials once you have enabled floworks, otherwise look for them on youtube that are there. also there are pdfs in English on the net with examples
