to become a dynamic block
Dani_73
hello to all people, unfortunately I did not find any other discussions related to my problem.
here is the description:
on my autocad program I have my palette with dynamic blocks as well as a file of origin where all these are saved.
during drawing, these blocks are properly arranged for the creation of an electrical installation. when everything is finished, we often have to send documents in dwg to architects rather than pdf.
necessary, not to distribute the dynamic blocks to free after all the effort and time employed, to have a command or a program lisp that can keep me the block at the current state but eliminating all the parameters and dynamic actions.
to explain to me better, when I take a dynamic block which can be ironed, or, a block with more visibility, when this explodes automatically deletes parameters and actions of the blocks, and keeps it exactly as it was placed in the design (e.g. elongated by x times, or with different visibility)!
I would like to be able to do the same procedure but without the blocking it explodes completely, but that it still remains as a block and under the appropriate layer!
Would someone be able to create a similar program, or redirect me to a download? ?
Thank you very much in advance
Sunday morning,
Thank you very much for your help,
the concept is centered great!
There is a problem, with this type of program I should select to one by one every single dynamic block present on the whole design, if you know one where I could pull a curtain and select multiple blocks at a time?
for the moment thank you very much, very useful
