transform a 3d design of solid edge into 3d in autocad 2006
  • Thread starter Thread starter emanuela86
emanuela86
I don't have much experience in drawing....
I wanted to ask you if there was a chance and you could help me solve this problem:
I have a solid edge file in 3d to always export to 3d in autocad2006... .
1st question: can you ask? ?
2nd question: if you how??? ?
I do not know for nothing solid edge and until now I have designed in autocad only in 2d but for work needs I should have files in 3d....
I managed to save several views in 2d from solid edge but only this...
Can you give me a hand? ?
Thank you very much to all.. .
hi, I don't remember now if solid edge exports in sat format but I think so. if there is this possibility export the 3d of solid edge in sat format (magari version 4) and import it in autocad (from the menu "insert" selections "file acis").
quot...
cation
Thank you very much. .
I've seen that it works but it doesn't show me as solid anyway but as a set of lines and on a part it only shows me a line...
I send you for knowledge the result given in autocad...
but did you save the solid edge table in sat? you have to save the 3d model in sat not the two-dimensional design
What do you mean like a set of lines and that only shows you a line? ? ?
the drawing appears in 2d.
