Random86
Good morning, everyone. I am a student of aerospace engineering and for the thesis I have to realize a model of bulb+derive for a sailboat more various fitting solutions.
I realized the mesh of the model with icem cfd; exploiting the symmetry of the problem I considered only half of the domain. Moreover, I imposed the transition from laminating to turbulent inserting a plan within the computing domain. as solutor use fluent.
the account is incomprehensible and stationary and has as objective the calculation of resistance and wall efforts (on the bulb and in particular in the connection zone). for this reason I also inserted a mesh of limit status ranging from 1 to 200 y+ to be able to use the enhanced wall treatment. the mesh is unstructured, with layer mesh limit to pentahedri ( prisms as it calls them icem) and then tetrahedri outside. Now, once the mesh in icem I checked it to verify that there are no errors, and in fact it does not return any error. So I went to fluent analysis. uploaded the mesh, I defined the model as k-eps feasible with enhanced wall treatment; I defined the speed in the inlet and a pressure condition on the outlet, while the plan inside the domain, which divides the laminar area from the turbulent one, I defined it as interior.
once I do this, when I launch the account (re=10^6), I get a warning message like:
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in tot cells
where the number of cells varies with interaction. In addition, known that the residual of the continuity equation does not converge at all, but rather almost diverges, as the value of the resistance coefficient.
thinking that the problem was related to the separation of the domain in two I also tried to launch a completely turbulent account, but without any acceptable result.
I also get the same problem both that you work on a mesh of a million elements, and on a seven million and passes. Can anyone help me? ? ? ?
