ultrawide monitor or 4k resolution generally
  • Thread starter Thread starter Atreiou
Atreiou
someone is using ultrawide monitors with solidworks ? with recent version type 2018 or beyond
or does it use 4k resolution?
I am smelling workstation change, which will be of, I would like to choose monitors too
I currently use two 24" in full hd
but I'm curious about the ultra wide monitors to be able to have a visulization of the wider sw working area
hi i am using it with inv 2019, it is definitely convenient, you can expand the feature manager and keep everything under control without sacrificing the work area or you have a greater visible area. I use an ultra wide lg 25" 25um58, 2 hdmi indresses selectable from the screen.
I'm trying 34" 1080x2560
It's the square. Beautiful feature manager wide, beautiful large library and a 16:9 window with the axieme. .
I don't think I'll experience the 4k
in the office I am using a samsung lu32h850 monitor with displayport cable with p4000 graphics card. the resolution is set to 3840x2160. Well I have to say that the difference is seen compared to a full hd; surely the area is bigger. at home I still have to test the 28" asus always in 4k resolution.
only thing that needs to be adjusted with windows 10 resize
