DavideDM
Hello everyone, I write you because I couldn't find any answer on the net, and I hope in your support. the problem is this: to understand how to make simulations in ansys regarding assemblies of parts in 3d, and its contact motions, I created a stupid example composed of 2 pieces in contact, I specified the contact areas and I started the solution (3 hours of calculations, I think it is necessary to understand how to set some things to avoid this, but it will be the next step).
Anyway I have the solution and I can see the tensions and deformed it, but only on all the asses.
the question is: how do I "delete" a component and display the tensions present only in the remaining piece, which otherwise would be partly hidden from the component to which it is coupled?
thank you in advance to anyone who will answer me.
