ApeGana
Good morning, everyone.
as from object, I installed the viewerst8 on win10. it does not work well: it opens only a few files, only with open command and not from explore resources, and then occasionally it blocks and gives a strange error (server rpc not available).
Do you have similar experiences? I until now used it only on win7 (maybe even 32 bits, but I'm not sure) and it was fine.
is it incompatible with win10?
second question: if I install a more recent viewer, can I have problems? Is there any risk that you can no longer open your designs with solid edge st8? Has anyone done that yet?
third question: I saw on the siemens gtac that the viewer for the st10 is no longer there! on the other hand there is a certain view and markup.... Is that the same with new name?
thanks to those who want to answer.
ape
ape
