cacciatorino
I don't know how to answer that.... I don't know anything about surfaces!:frown:Besides: how does it work if with the surfaces? do you have tangency controls and curve continuity as with swx?
I bought the r8 auditorium tutorial and I'm doing it at hours lost. I'll tell you I didn't even think swx could do anything like that.I don't know how to answer that.... I don't know anything about surfaces!:frown:
one thing I liked and that I find useful is the possibility together to do the section having the possibility to go to touch and edit directly what I want to retouch.better in what, say it, that we don't know if? Do you use it if you have noticed that swx does something better otherwise you wouldn't have that impression, or did they hypnotize you? :wink:
there is the environment "structures" that grossly does the same thing, that is, starting from a unifilare scheme realizes the welded axieme (as assembly and not as a multibody part). I don't know how it works because I don't have a license to use it.another thing: did you try the welded? Is there anything similar in itself?
I don't know how to tell you why I don't use the sheet of myself, my basic license (that of 3000 euros before the discount) is not provided.Besides: with if you can develop a slodge on the floor? Can you create round tube joints with prependicular cut so that those who cut them with cnc can use 100% your model? can develop calandered profiles like upn - he - square tubes, etc...
I would say yes, the communication solidworks - excel is great and becomes super if you can use some vba. I saw some spectacular footage in which an excel sheet made the calculations and after the modifcihe pigiava a button (in excel) and built the swx curve. this film was made with 2008.I would like to ask you, can you make profiles of a cylindrical cam with variable pitch editandola from table excel as can happen with if?
I chain the models so almost real. the management of the chains and straps is unified, but for the chains it is not the maximum (my opinion).Can I make a step sampling on a chain path? with if you...
is a standard function, which can act both on the sketches and on the pulleys directly in assembly.Can I mount a belt by adapting the automatic pull to the length of the belt? with you
But why would you want to change if you're okay with it?Will sw give me these things? Losing them would be a shame
it is not necessary and you work very well lost. with tab builder do it all very quickly, if you take an office you also have task scheduler that allows you to plan the builds of the properties automatically at night (at least for the common ones). Also there are a lot of macros on the net to facilitate this and many other operations, you can find many links already in this forum.last question, why do you think in sw it is necessary to use a pdm?
They say it works well, but I can't give you directions. I have colleagues who use it and manage to achieve what it takes.It wasn't the last...discussed... but inventor at what level is it?
in swx is included in the base, so if with swx you need a pdm to fill some shortcomings than if, perhaps there is other than equally useful already in the base. as I said a test like yours can not give a truthful result and I explain why:there is the environment "structures" that grossly does the same thing, that is, starting from a unifilare scheme realizes the welded axieme (as assembly and not as a multibody part). I don't know how it works because I don't have a license to use it.
Then there's the welding environment to put the cords and the various work related.
there is a small misunderstanding: the basic license of if (3000 euros) starts from a much lower level than the basic license of swx (6500 euros). the comparison must be made between foundation and swx classic that travel at the same level of price.in swx is included in the base, so if with swx you need a pdm to fill some shortcomings than if, perhaps there is other than equally useful already in the base.
the student version of swx is equal to the classic big way (only the export flters to step/iges remain.- you used a limited version
- you did not do any courses and learning from self-taught you try to do what you did before, but swx is not if and you should work by taking advantage of swx strengths and bypassing weak points. I'm sure if I taught you, you'd have another opinion.
That's a good word.I close and add that the best cad in everything does not exist.
in this case if you take osd you absolutely need the "animation" module or as it is called, otherwise you do not have the constraints of together and therefore you cannot realize cinematisms. .I will work little with surfaces and much with real animations, cam profiles, transport chains... with these directions do you have any other suggestions?
I'm sorry what exactly you mean by saying file management is better?and even in file management, indeed perhaps it seems even better,
You mean direct editing? I think they're very different and difficult to compare.more compared to that mess of the st if there are no comparisons.
and I also reconnect to this:I'm sorry what exactly you mean by saying file management is better?
also because so many functions available in the property management are directly placed on the table, there is then the simplest management of the files that with a simple save are renamed, the part that divides creating a multibody without need to have a set, the matrix or sampling or mirrored part that also maintain the constraints and movements of the father, and here I make you a stupid example:cacciatorino said:However, I don't have a negative opinion of swx, I'm just saying that for my way of working if it has something more than speeding up my daily purchase equal work, and that for having the same features (propie manager, revision manager, variable table with integrated spreadsheet)
It seems to me that they are things you can do even if, I studied a good month swx and found it worse in everything except configurations.and I also reconnect to this:
so many times with if I started drawing and then for one reason or another I had to utlize the left part of what I was drawing but the good and sincere if it created me si the twin sx but stuck without constraints and with all the work to remake, without then talking about a hand of grip...
I know well that they are 2 different modes but known that around there are just a few people who use it, most even after doing upgrade courses prefer to use the "classic" version, not only, many of them still use the v20... and we stopped at 3 years ago about... then mine is an opinion, I do not want to make controversy, I am answering myself in this discussion and for now I am using the demo of swx who knows in April how many surprises with the beginning of the course!:finger::biggrin:
and I add that the important thing for all and find yourself well with their shoes, creating as much as possible their own opinion based on facts and not rumors.I close and add that the best cad in everything does not exist.
questo e' sicuramente vero! :biggrin:points of view, moreover
