change altitudes
  • Thread starter Thread starter rober
rober
Can anyone help me? I have a quotated plan (high-level rates) in 2d, is there a way to report quotas to a zero other than what I have? I explain better, from topographic relief zero is reported to the starting station, and point 10 is to -5.30. Now I would like to bring zero to point 10, so all the quotas must be decured or added of that entity.
Is that possible? the quotas are informed text.
It's possible.
command: move
select objects:
specify base point or [Spostamento] <spostamento>:
specify second point or <utilizza come="" primo="" punto="" spostamento="">: </utilizza></spostamento>.xy
di (manca z): 5.30then delete all quota texts and use the autosez 2 program of gp to recreate quotas
http://www.cad3d.it/forum1/showthread.php?t=17601
if I have a 3d, but having a 2d, how do I modify the quota texts, all of a certain entity?
I didn't read that "2d." I thought it was 3d.
All right, you need to increase all numbers by 5.30. in this case it takes a lisp.
However I solved, towards the last pages dedicated to the lisp, there is a folder with various lisp, inside I found vartxt, which is exactly what I was looking for.
thanks and greetings
