export files from windchill without creo license
  • Thread starter Thread starter maksimon
maksimon
a customer has all the technical database on windchill, recently they no longer have a creo license because they decided to run the mechanical part to us that however we use solidworks and we do not have a plm.
now the problem is that having no more create we can not save files externally. from windchill is it possible to export files without a creo license?
hi, you can export the data cad, but you have to use windchill workgroup manager, from the browser you can not. probably also varies from the version in use, we use windchill 11.0. if you have active licenses for windchill you can go to the ptc portal and download windchill workgroup managers. I'll put you a fresh picture. Hi.
If you want to do a unique operation for different designs I don't know.
from the commonspace, as from the workspace, if you press the drawing information button ("i"), go to the "content" tab, at the bottom of the page you will find a miniature drawing. If you click with the right button on this, go with the cursor on "files" and select the pdf format allows you to download the table in that format.
Good luck
... we can't save the files externally. from windchill is it possible to export files without a creo license?
the problem is that the license of whidchill and creo is incorporated into a lic file and installed via flexnet .
If the crack has expired, the windchill will also expire.
I think you can't do it, but I'd be happy for you if you can.
to export the data from windchill also needs the application they were created with... so if they were made with creo you also need this license.
of course also the windchill license
