file instructions and/or journal solid edge st3
  • Thread starter Thread starter Nicol
Nicol
Hello everyone,
I'm a graduate of ing.mechanics. I made a wind blade (geometria 3d) in solid edge st3 ed devo optimize its geometry usando il software fashion frontier 4.4; to do this, I need it instruction files and/or file journal of geometry made in only edge st3.
How do I do to extract it and import it in modefrontier 4.4? in which format do I have to save 3d geometry?
I'm not familiar with modefrontier yet.
Thank you very much.
ps: I attach an image of the wind blade (profile nrel s809).
What is the instruction file and geometry journal?
solid edge can export 3d geometry in many formats you have to see modefrotier what is in degrees to import.
p.s.: immediately at the beginning of the profile of the shovel there is a leap of continuity, is it a thing wanted?
the goal is to create a loop between the following softwares: solid edge st3 – fluent – modefrontier.
at each loop, modefrontier, on the basis of the cfd simulation, optimizes the geometry created with the cad and the “go back into the meal” to fluent. modefrontier generates parameterized files as input for cad: instead of manually recreating geometry, this optimizer is used. summarized, modefrontier works as follows:
-imports the parametric file of geometry;
-create the new geometry.
the instruction files (o file journal) is a list containing all the operations that have been carried out to achieve geometry; in a few words is an executable that, in general:
-can be created with a gui and you;
-can be created or modified externally with a text editor.
summarizing, instead of creating any geometry with the mouse, you can write a list with all the info on geometry; it launches with the cad and the geometry appears. This is an advanced cad command.
would be something similar totogether of the operations contained in the promptbar.
it is possible to makereverse operation: starting from the geometry created with the mouse, you can extract the journal file (a)> point created coordinates\ 0,0 1,0 2,0.......... > undo.... > redo... created surface\..”).
to better understand what this is about, at the following address we talk about the file journal of another cad: gambit. http://willem.engen.nl/uni/fluent/documents/external/exploring_journals.pdfthe discontinuity you noticed is desired. :finger:
I don't understand that solid edge allows this mode of export, but maybe I'm wrong. you mean something similar to the file "trail.txt" of pro/e, that is a maxi-macro-education that contains all the steps of modeling. But the soft you're using doesn't tell you what cad is compatible with?
p.s.:
I answer myself:http://www.esteco.com/modefrontier/modefrontier-integration-nodes
Yes, I mean something similar to the file trail.txt of pro/e, or one script del file .par which can be used to create the model.
I consulted the site you linked: I confirm the answer you gave yourself! of the various cads with which modefrontier interface, solid edge seems that it is not part!:wink:
ps: if someone has more info about it, do not hesitate to write here. from the various discussions present, it seems that no one so far has "disputed" in this problem.
It's a niche application, normal no one heard of it before. I remember that in the basic fem of solidworks there is a similar function, but it's extremely rudimentary and I don't know how useful it is.
What interests you is really in the field of futurism, and sincerely I don't know how much it can be so fundamental, compared to the traditional fem analysis followed by a critical review of the model made manually.
I see you generated the profiles of the shovel using curve by table.
if this software really does what it says you should instruct it to update excel tables of profiles, solid edge will update geometry accordingly.
