7sc6tu
Good evening, everyone.
I recently started using catia v5 r19, after working for years with autocad lt.
I immediately began to have a small problem with previous saved designs with autocad in dwg and dxf.
I explain better: how much these cat drawings opening a new body and a new sketch, but after doing this, I have to give all the constraints to the figure because otherwise the solid does not create and tells me that there are many points/elements open.
the operation of "rivincolare" and repassing the whole figure takes me away a lot of time and if it is possible I ask you some advice to avoid this laborious operation.
Thank you all.
steak
Thank you all.
steak
