liber
ok for 2008 you can not, but who knows!!! :biggrin::biggrin:but the discussion you read or pretended?! Wake up! you can't!
have you installed a 32 on a 64?? ?ok for 2008 you can not, but who knows!!! :biggrin::biggrin:
the screen speaks for itself and is autocad 2006have you installed a 32 on a 64?? ?
What?the screen speaks for itself and is autocad 2006
everything is cleaning the setup from the lines that refer to the netframework
How do you do it for ordinary mortals? I didn't get a snitch!Liber, you know you're a donkey, right? (No offense :wink: ) autocad 2006 did not exist in x64 version and therefore install it even without making that useless turn. Moreover what you have installed is a civil autodesk 2006 and on civil I give you a good news: try installing the 2010 x86 and you will see it goes on equally, since the first release released for os x64 is 2011.
the only way to install a x86 version on view or 7 64 bit is to open the nose with orca and change the installation package
http://msdn.microsoft.com/en-us/library/aa370557(v=vs.85).aspx
I don't have them. being downloaded from the autodesk site, it is only one file that once downloaded does everything automatically...it is not divided into files.What's the cost of zipping the two cd setups.ini and then I see if you can do it? ?
Come on, you got it? it was "affective." If I wanted to be offensive, I would have used another term:wink:I would say to make an earthly attempt from "bean" what I am, changing only the setup.ini
Look, I'll tell you, I've done a lot of installations but this problem of the .net framework I've never seen because, if they're all installed, autocad takes what he needs. Then, for love, there can always be a loser...personally I have always considered the donkeys of the beasts smart enough, then each of us has some potential one arrives to a goal maybe another overcomes it and vice versa, otherwise where is the competitiveness? ?
cmq you have not answered about the setup.ini described here and the installation difficulties also in an operating site xp professional updated to the netframework version 3.5
