laundry surface, where am i wrong?
  • Thread starter Thread starter painaz
painaz
in a set of solid edge st (100) I have to create a component that I prefer to shape as a surface.
the component is seen in the figure, it is a metal seal. I never use the surfaces, but I thought it was easy: I use the command "superfici contour", but the feature fails (loop must be closed) if I include the edges of the holes for prisoners (three small holes) and the edge of the cylinder barrel with beamed light. if I only use outer edge everything ok.
what is the right technique to make a simple laundry surface?
thank you for those who enlighten me
You must first make the "non-cleaned" surface and then cut it.
I don't understand why you prefer to go through the surfaces.
you force yourself to use many commands when with one protrusion you can do everything.
In fact it is to cut it that I am dismembered.
I prefer to use the surface, also because I have another thing in mind: on some areas sometimes you use the loktite (small example pinion, forces and low pairs, I save the tab. But I want it to appear (loktite) in the boiling table. I don't know if I explained in a hurry... .
Okay, I thought you had to make a sheet.
I create non-graphic parts for this.
to cut a surface you have to be a reference object that represents the cut, for example a sketch.
