I apologize if I've been sensible these days. .
I tell you what I should do: we make welding islands, assembly machines components and so on
in all our machines we always have a product that either is the structure in profiles or is the electro-welded that keeps everything (robots, pictures, motor etc.).I want to make so that every time I make a machine from zero cup and neck (interrupting the links both of position and geometry what I told you the other day) so I can quickly change depth height and width without having to remake all the structure from zero
I tried with the new to and get what I want.. the problem that then saves my parts with a _1 at the end and is a slam rename the files.
Monday I tried what you recommended (send to ) but it keeps me links in geometry and so if I change a part in the new folder I also change it in the old
I can't figure out where I'm wrong. .
attention that the speech is complicated. . .
it is not possible that by sending to if you change a part in the new folder also changes in the old! open rescue management and check folder bets. . .
certain things happen if you do not master the saves, or if you do not consider that catia keeps in memory the last loading for which it is to be closed and restarted every time you work under conditions that can create "cross" in the files, type equal names in different folders.
I try to give you some suggestions, maybe for you are obvious things, but I would do so:
we start by saying that if a product or part is modified, it must have
always a different name, so the product (to make an example) "isola_di_saldatura_
standard.catproduct" when modified, must change name to "isola_di_saldatura_
assa.catproduct" and the new electrosald that will be a part, when it is modified it must change name (to make an example I put him some hypothetical maximum size) from "electrosaldata_
standard_
1000x500x300.catpart, while all other parts
that are not modified but they rest from the electrosald never have to change their name and the ideal would be to take them from a common library.
so at the beginning of work, I create the new electro-welded part_1000x500x300.catpart with a new da, setting the size I need and the correct name, and then in the product I replace the standard electro-welded_standard with the new one, in this way all other unmodified and bound parts should adapt to the new measures. Obviously the constraints must be put on public entities so that they are not lost.
at that point since the product has changed because it contains the modified electrowelded, you save it with the new name, better it would export everything to a dedicated folder.
Let me know.
