save in step files
there are people with the same surname hahahah
and anyway it would not make sense the name you gave to the profile because maybe tomorrow, for necessity, I need to do it 600 long and I have to give it back the name.. think if I had to do this for a structure with 20 different profiles
with 20 different profiles you will simply have 20 different names.
It makes no sense to have different pieces with the same name.
I don't understand what you mean. the table of the profiles I do not really do it in single profiles or overall structure because it is useless, just the step then thinks of the supplier.
the individual components that work by machine (fresh, lathe, fold) will have n° commissioning.position
I will never have in our entire server two working components with the same name because the order changes
provided that the overall structure in profiles is still a working component (external but always remains a working component), I can also understand that you provide the step and do not make the table but leave him the same name sooner or later he'll make you trouble. put that for a customer (same commissioner) you have two matching frames, one long 2000 and the other long 1500, you are however obliged to put the right names otherwise do not load them together.
Since you don't do 2d and not even separate base, I imagine and hope that you overall profile it in multibody.
