Abe77
Good morning,
has been trying for days to create a circular extrusion surface on which to extrude in turn wrapped numbers: what
I would like, in practice, to decide the number of extrusions to be represented and to make the first extrusion have number 1, the last extrusion
have the number I have decided, es 40: I have operated through equations to set the diameter of the extrusion surface and I have tied the text
to a line whose length is the development of the extrusion surface; In this way, however, I must write the sequence of numbers by hand and the wrapping of numbers does not come to the bottom, I do not know why, as I do not know why when the text becomes 2 digits (e.g. number 10 rather than number 1, the 2 digits are particularly distant from each other)
with the circular repeat command, instead, I cannot create an incremental function with the extruded text linked to a variable of the functions,
Does anyone know how to do it?
Thank you all in advance,
Tree.
Tree.
