"structural" couple positioning
  • Thread starter Thread starter emi_973
Hello, everyone!
I used the coup beam to cover a roof, but putting it on a converse layer position the plugs incorrectly. How can I solve the problem?
I'll take a picture.
Thank you very much
I think that in converse the hoods do not put- otherwise you should put them under and flipped. Or not?
The only problem is that as you see in the layer at first they are just then puts them wrong.
I saw. I thought, erroneously, that you wanted to put a converse plug. the two bonfires have the same slope and the converse line is on the bisettrice of the angle formed by the meeting of the two bonfires, I imagine.
Yes, the bonfires have the same slope and the conversa line is on the bisettrice of the angle formed by the meeting of the two bonfires
in the photo, if you look at a layer you see that at the beginning the plugs are aligned and parallel, instead in the converse they are thwarted.
Unfortunately in this project I need it for force, I did not try with the continuous facade, because I can not put the plugs
