windows 10
  • Thread starter Thread starter gfrank
I wouldn't install it anyway immediately, I will definitely wait a few weeks to hear the impressions of those who update from windows 7 (which I currently have), if it creates problems, if it penalizes the performance of the computer, etc... then I will decide.
but in the end it is almost sure that I will try it, also because I can always restore the computer and return to windows 7.
excuse the question but the backup of the data before the switch to w10 is necessary?
I asked around and heard about all the colors:
no because it is a soft transition to a new graphic interface, theoretically nothing is deleted
Yes absolutely, it is indispensable, the record will be reformed
but it is not necessary
Can someone competent answer (maybe first proof ;-)?
I didn't update.
still updating not formatting the disk. if everything goes as planned, the data is not lost.
but as we talk about a consistent update, some problems could jump out. so the back-up is highly advisable.
the distribution of windows 10 better say the download of the update.
Has anyone installed yet? Are there problems with working software?
I saw a colleague's notebook this morning (not very recent, he's already 5 years old); last night, to say in half an hour, no problem with sw type office and other installed (no cad though).
I just took a quick look, I can't say anything except that the interface finally seemed to me something usable on a pc.
My $windows.~bt hidden folder has already arrived at 5.19 gb .... but they didn't say that in all it was only 3 gb?
to targeted demand the most recent visicad/cam are not guaranteed x w10. so I will wait for reassuring news from them first of all.
wanting you can download the offline version of the win10 setup, and decide whether to create an installation support iso or usb and make an update (which will allow you to hire the current product key as original) or a clean installation (but at this point it takes a poduct key to buy or follow the notes indicated).
Obviously the advantage of a iso or usb is not to have to download 3-5gb on each machine that you go to update. . .
I put the link for those interested.http://windows.microsoft.com/it-it/windows-10/media-creation-tool-install?ocid=ms_wol_win10
I'm using this system. the download took all night, going like 70 kb/sec, evidently not to saturate their servers have dropped much speed. I am now installing using the update function, then I will create support.
confirmation
for full installation (on laptop) takes a half day.
I'll be there
if I am living from w8 to w10 and having already with w8 all the package microsoft 2013 after the update I will still have available microsoft 2013? ? ?
with the update, all sw installed on my laptop (excluding those of microsoft that are declared in the warnings of win 10) were installed and operational. the most important,office2010, revit, software acca, docfa, pregeo, etc. ) work regularly : I opened archived files and everything works regularly.
even some sw "data", with win 10 seems to work faster.
with win 7 the s.o. and its applications, it was loaded in about 3/4 minutes: without touching anything, win 10 is loaded in about 90 seconds...
the traditional menu, is not exactly like win 7: the main folders are listed and then all sw. if you had rapped into secondary folders (list) are not shown in the menu. For example, my acca folder was subdivided into secondary folders (safety - accounting- etc...) in the menu is reported the main folder (acade) and then all sw : primus, certus, etc..
the changes to the main menu, you must make them in the folders where the menu files are allocated, and not directly from the menu itself (as in win 7).
of course, you can organize everything with the apps menu (as in win 8), dragging from the menu to apps
there is some problem with java, whose update you have to do using a browser other than edge, which is not yet 100% compatible with java
mark also this post of mitho87 that updated and, after finding problems with inventor, posted the solution
http://www.cad3d.it/forum1/threads/45421-inventor-2014-windows-10-non
- - - updated - - - -mark also this post of mitho87 that updated and, after finding problems with inventor, posted the solution
guys, I don't know you but I after having booked the update (force a .exe found on the web) I have the symbol on the bottom right.
if I click above I can see that I am on the waiting list but today I have not yet been able to update.
I also have the information that the necessary requirements on the machine are respected.
He tells me I'm still getting the message for the upgrade.
I also tried with this procedure but without outcome:if you still do not see the $windows folder.~bt or if you notice that however download did not leave, you can force windows to upgrade and download windows 10 by opening the command prompt as administrator (from the start menu -> programs -> accessories in windows 7 and pressing the right button on the low-left corner of the screen in windows 8), write wuauclt.exe /updatenow and sendHow'd it go?
possible that I am the only one with this problem?
I have a noterbook hp with windows 8.1
Thank you for your help.
How'd it go?
I also had to wait a while before pressing on the windows icon, instead of the usual msg saying that my reservation had been acquired and that etc.. , the msg appeared to me that the update was ready.
when I threw it ( pressing the ok button that appears on the notification ) it ticked ....:mad:
then I found on the site of the microsoft a download page and from there I launched the tool for the update. (Council : read the instructions well)
https://www.microsoft.com/it-it/software-download/windows10I have to say that windows 10 works well, I didn't have any problems with the software I use habitually.
not even changed the desktop I had in windows 7, all icons in their place:biggrin:
notebook acer windows 7 professional 64 bit
Okay mariuss,
Thanks for the answer.
I read that you have to keep at hand the product key code of windows.
Was it like that to you?
Any special advice to give me based on your experience?
How long did it take?
I stubbornly wanted to install win 10 on my, now vetusto, m2400 although it was not yet certified by god.
apart from a problem on the video driver (the brand new one installed with the update planted the laptop after 10 seconds) solved by reinstalling an old driver (2010!) everything works regularly. as soon as the start menus were not working at all, I could only use the text menus with the right button. almost desperate I had decided to reinstall everything with the old so win7 but after a long search on the web I discovered that many had had the same problem (and not only during the update). I found a command that from (awesome) programming mode in dos rebuilt all the menu by reconnecting the installed programs (practically the old registry file had some casinos and the menu had no more links) now everything works great. Taking into account my laptop age was almost crazy, but it went well. good news for those who fear compatibility problems with the past (remote). :
Okay mariuss,
follow the instructions of this article ... the product key will automatically activate if you have a genuine copy of windows 8 or 7.
I didn't create the iso file on dvd, but I chose the option " update the pc now"
during the installation you have to have a lot of patience and never be taken by the doubt that it has stuck (it has to download 6 gb of data before starting..) also the pc will reboot' some times.
to me it took 3 hours to complete the installation, but everything depends on your adsl and the features of your pc.
( adsl 10 mb download / notebook intel i7 2.2 ghz / 8 mb ram / hard drive ssd )
Article 1http://www.ilsoftware.it/articoli.a...za-attendere-il-messaggio-nella-traybar_12546Article 2http://www.ilsoftware.it/articoli.asp?tag=installazione-pulita-di-windows-10-e-product-key_12553
I didn't want to install it, not immediately, but......... he installed it on a pc that I think + old than that of the president.
Everything works......
Hello.
last night not having the opportunity to update it I got caught by a raptus of madness and I downloaded the tool from https://www.microsoft.com/it-it/soft...load/windows10 .
after half an hour I had the tool ready for installation.
without worrying about the various backups I clicked on accept and installation is gone.
It took three hours.
once all installed, I unmaned some options, colors etc.
I have restarted the notebook several times and so far no problem.
icons and links are in order.
I have the impression that without my pdecident I could have waited much longer, perhaps too much for having windows 10.
Thank you for your precious advice.
