probably your hard disk on which you installed is not c:Good morning.
I happen to have come across this discussion today, and I believe that this plug-in was very useful I tried to install it by following your instructions, I don't understand where I'm wrong but I get out of this mistake that I attach:
Thank you in advance
...ops.. I actually extracted files in a desktop folder and not in c: now it worksprobably your hard disk on which you installed is not c:
if it was different from c: you have to edit the .bat file that records the dll.
Let me know.
Thank you, I'm sure and I think of many others, thank you againGood morning, everyone.
I attach Rel. 4.0 to savebackground, after so much expectation.
This version allows you to save files in different paths than the source file according to the modes you see in the attached image.
I have not yet entered the export in "stl" format as required sa xxfast, che salute.
Now we can define a rescue path on which our converted files will go, or automatically create sub folders based on the extension inside the file's residence manager.
remains always in foot the saving of the file in the path of origin as before, without under folders.
installation:
- as for previous versions extract the installation file from the .zip file and launch the program that will install automatically.
- in the case of previous installations in the pc will be overwritten automatically.
inside the zip file you will also find the updated guide.
I hope I was able to settle someone.
This version works very well and I am using it with solidworks 2018 sp5.Good morning, everyone.
installation:
thanks for your add-in, it is very useful.In fact it is true, it does not keep memorized the choice for the target options.
I'll see to fix this in version 5.0 where I'll put something else in.
Thank you for saying that.
Good day
Hi.thanks for your add-in, it is very useful.
I ask you if you have developed another "help" I often do this:
I have pippo.ipt
apro pippo.idw , I save with name pippo.ipt in pluto.ipt
pippo.idw reference updates, I save with name pippo.idw in pluto.idw.
I ask you if there is a way of intercepting the command saves by name of the parts and the assemblies and automatically rename the relative table.
thanks for the answer
