gricozzi
I finally send some examples of isometrics, especially those of power. I will send you more examples as soon as I can.. .
on the points raised by my last intervention I would like to stress that at the time when the official channels of the support will notice a mistake such as the one reported by the drivers will be cadmatic development to solve it urgently, being clearly a malfunction on your project!
on the need to change in autocad besides the materials I do not find myself online...in cadmatic the graphic modification is feasible inside the pipe tool (even if in the new version 6.1 is now called isometric piping & spools...so it will be longer to say the name of the module that pull out an isometric in demonstration!), the only change that will never be made to do inside the isometric module (and here if confirmed the error on the weights I agree with the comment of marcobi, there is evidently some configuration error (it is aimed at a wrong attribute for certain components?) or lack of data (some attributes are empty?) if the weight does not come out correctly.
I would like to go and integrate another information: standard settings are used in case the project starts from the official (empty design) base, in case we are talking about it is not so, it started from a project made in 1996 (!) and then converted to version 6.0 (from 4.1 if I am not wrong). this operation has given advantages (as well as being feasible without problems in cadmatic, which is not so discounted for others!), but in this case it has also "jumped" standard configurations on the exit of isometrics. Despite this it remains always true that the administrator will always have to finish these settings on the project, as pointed out also by other comments.
